At o dark thirty this morning, I look out toward the toy box (shed) and it looks like there's a light on. Funny cause thers no lights out there, just wheelers and lawn tractor on battery tenders. I wander out, open the door only to see the 550 all lit-up. The ignition key was off. Cycled the key on n off and lights went out.
I've ruled out the homeless, ghosts and the Popos never complained about bunking with the CannedHam so what could it be?
Lol!
I'm thinking the electric control module is malfunctioning.
:hmmm:
If your battery tender is hooked to the 12v outlet in the pod, the battery tender will keep the ignition alive, if you hook the battery tender direct to the battery, then its probably a solar flare or something,
