i posted a few weeks back about a "lo 10.8" sign that pops up when i use my lights. i did replace my battery and it still does it
Does this seem like i need a new rectifier or stator?? i am no mechanic lol!!
it is a brand new atv. 2015 sportsman 570 eps (camo color) and it is very frustrating that i cant ride.
anyone have this issue?
If you have a volt meter that will read DC voltage, you can check the voltage at the battery or at the area under the front storage and see if it is charging. I'm not sure what it should charge at on an atv, but it should be higher than 12 vdc while the atv is running as long as it works like a traditional charging system. I would expect to see around 13 vdc. If you don't you may be able to borrow one from an auto parts store.
