1 - 20 of 24 Posts
Anybody have a decent picture of their lock & ride cargo bag, the one made for the Scrambler? The picture on the Polaris website sucks and I'd like to see more before I spend the money. Thanks
I dont know the line for scramblers so well///
This is a Sportsmans box if it helps.
The bag isn't exactly water proof I gave mine a few coats of "camp dry" and that helped a lot! But it's a great little bag that fits the contours of the rack perfectly and actually holds a good bit of gear in it!!
I wouldn't buy it again if I had the chance. The zipper sucks, any hint of dirt and it stops working. I'm planning on selling mine and getting the OGIO Burro bag with the additional rack needed.
This is the bag I want. I might get it to see if I have to get the accessory rack.
I'm thinking if its not too big based off the dimensions listed for it, I might put a hard base in the bottom and mount it with L&R clips on the inside, therefore eliminating the need for the accessory rack.
Yea sometimes those straps rip right off even under lighter loads. Our koplin did.
Isn't there something you can use to lube stubborn zippers ? I read once that bar soap helps.
That is a sweet bag SnotRkt! I sprayed some wd-40 on the zippers and that helped a lot! But if you cover the bag in mud the zippers can be a bitch!
The bag attaches with lock and ride anchors to the existing holes on the rack similar to the anchors on your front rack! I use the kolpin anchors on mine there better than polaris's
I had mine on for one ride then threw it in the trash. 175 bucks wasted. I liked the design and all it would have been handy but its made of crap and the bottoms water proof and the top isnt
I used some spray on dry silicone on the zippers and tracks, rubbed it in good, worked like a champ. Reduced most of the sticking zipper problems.
The camp dry spray on the entire bag worked good too!
Snotrkt, did you ever try out the Burro bag. I have to have a bag and the polaris one seems sketchy. Would love the burrow but hope I don't have to buy the extra rack as we'll.
What extra rack are you talking about RichV
1 - 20 of 24 Posts
