I got the little one finally but can't find part number for the one below the gear. All parts pages have it as a whole assembly
The one behind the gear is a special bearing - it comes with a complete lower end bearing kit.
Take it to a local bearing supplier and see if they can match it up by dimension. Polaris never offered it as a separate piece because when the water pump shaft was damaged it required replacement of the counter balance. Since the projected life of the engine was less than 10 years, not many replacement counter balance shafts were allocated.
