I need a new inline ignition tester that will will work on the Polaris 570, 500, 425 etc... My lawnmower ignition tester with the alligator clip doesn't reach down in there.
Thanks..
DTLMG
When I worked on cars in the 90's we would use a old spark plug. Just ground the outside to something.
The problem with that is its hard to see if there is intermittent spark on a single cylinder when its running. esp the overhead engines like the 570.
Timing light can work, but you can't run it off the ATV battery. Needs more juice. I ran mine off the garden tractor battery
