1 - 13 of 13 Posts
Hey guys, new here but ive lurked for a long time. Bike is a 2004 Sportsman 600 twin.
I was getting a lot of water in the gear box going through deep water but not so much in the air box. Problem im having is that I snorkeled the clutch running two 1.5" hoses up to the headlight pod. I left the air box alone except for installing a foam air filter and sealed the box. Now, it seems to run fine except when at full throttle and at near top speed it seems like its not getting enough air (or fuel) because it begins to sputter a bit. Didnt have the problem before now.
I plan to put new plugs in, change the oil and filter (need to do anyway), and run some 93 octane to clean out the carb but dont know what else to do. I thought about adjusting the carb but dont know if there is a adjustment knob or where it is.
Any ideas? Thanks
Welcome to the board!:med:
Ever try running some Seafoam thru it? This stuff is GREAT! I've used it not only in my vehicle but in my commercial mower. It cleans em up and makes em purrrrrr like a kitten. Could not hurt to try it.
The air filter its probably the main cause. It likely flows a little different, probably better than the stock one so you are a little lean, especially up top where it is really pulling air in. The 600s were also a bit lean from the get go from what I've heard. Step up 2-3 sizes on your main jet and that should get your power back.
Ill try the seafoam first but I think Ridinagain is right. Is changing out the jets difficult? And where do you recommend I get the parts from?
Dealer would probably be the easiest place to get jets from. They are only $3-4 each. All you have to do its remove the carb bowl and change it out. Very easy.
Look at the spark plugs, that will tell you which way you nbeed to go on the jetting.
White/grey-lean
black/wet-rich
Cardboard color-just right
Put tape over a quarter of the air inlet. If it gets better its lean. If it gets worse, its rich. Another way is does it run better when warm or hot? Running better when cool is a rich condition, better when hot would point to lean. You cant read a plug when its old. Also, if its not revving cleanly it will change how your plug looks. Almost impossible to read a plug on any engine that is not at least running correctly under load.
1 - 13 of 13 Posts
