1 - 8 of 8 Posts
I try to find a problem on my Polaris touring 500 EFI 2009. If I run my bike full throttle after 1 miles I am loosing power . I rebilt my 2 clutch spring bushing ...
I don`t have any start problem and if I drive at the same speed I don`t see the problem it is only at full throttle or if I clib a hill. Milage 9000 miles.Plug and air filter are new I did not see any wire broken. I went today in EFI Diagnostics and I found code 51 . Injector 1 Short Circuit to Ground or Short Circuit to Battery. Unplug battery still code 51. Do you think that could be my problem if yes code 51 is it a bad injector or wiring problem ?
Wow thats cool, on my last atv i just had 1,800 miles. I wish i could ride as much as you guys up there .:biglaugh:
1 - 8 of 8 Posts
