2009 sportsman x2 800---When the fan comes on it is very loud, almost like a bearing going out. Do these fans have bearings or are they just plastic? I do clean the radiator with water after mudding, is it possible that water got in there and rusted something? Is there a way to lube the fan so it runs smooth? How much would a new fan cost?
a new one is over 200 bucks and it comes with a new fan blade. you should take the old one off and see if the is a rock or stick rubbing against something. if the fan is bad you could check around ........ jegs had some universal ones for way cheaper than that.
Thanks for the info, the quad is only 4 months old so I find it hard to believe that the fan would be bad. At least its still under warranty.
yes take it in , if that fan quits the machine is done. it will overheat alot quicker then you can find a puddle to cool it. my friends has been doing this for quite a while it's goten so bad that it sticks and will not turn, I just give it a boost with my finger and it's good for the rest of the day lol
