Are you holding the throttle open? Check it with another gauge to verify it's not a faulty gauge or leaking connection to the gauge.
As I mentioned, I am not familiar with the quirks of some of these small engines but even though not a "professional" mechanic, I have built and rebuilt probably 8 or 10 car and motorcycle engines over the span of 50 years or so with success. So, I am not completely unfamiliar with engines. I am sure you have heard of a "warped" head on engines before thus the reason for installing a new head and gasket.Only the piston, rings and head gasket have have anything to do with compression. Other than that it's the length of the stroke.
It's obvious you have limited engine technician skill.
As you have found out, installing a new head did not change the compression - when you installed the new piston, did the top of the piston come to the top of the cylinder at TDC?
Yes. The arrow is pointed toward the exhaust, like the original piston position. I feel like I am just overlooking something. Only getting about 15 psi. on numerous tests at WOT and even with the carb and reed valve removed. This is really becoming a challenge. Thanks againAre you sure you got the piston in with the correct side toward the exhaust?
May have found something. Overlooked it when measuring the ring end gap.Does this look right to you? it's a pic of one piston rings inside of the cylinder. I have a light shining up through the bore and one end of the ring clearly is not touching the sidewall of the cylinder. Both rings are this way. Don't look right to me.Yes. The arrow is pointed toward the exhaust, like the original piston position. I feel like I am just overlooking something. Only getting about 15 psi. on numerous tests at WOT and even with the carb and reed valve removed. This is really becoming a challenge. Thanks again
Gotcha. Will gap as you seggested when I install the new rings.Typical new ring gap is about .012 to .015" on a 50cc two stroke with a service limit of about .024 to .030"
