had our 2005 Polaris sportsman serviced and while riding the oil plugged came out does anyone now if it has a low oil sencor thanks
Not sure whether an '05 has an oil pressure sensor, but you're saying someone didn't tighten the oil drain plug properly causing it to fall off or at least loosen enough to leak all the oil out? So were you able to put plug back, add oil and restart engine? :bam:
Welcome to the board!:med: I'm going to be in Lewiston next Monday for the whole week with the grandkids and family.
Welcome to the forums!
