1 - 2 of 2 Posts
Quick question, once the front lower ball joints are fitted in the A arms, and the circle clip is connected, does the ball joint still have to be pressed into the hole, or is the repair completed...thank you
If you've got the ball joint in the hole and the snap ring on it and seated so it can't get back out then that's it for that particular joint.
1 - 2 of 2 Posts
