1 - 13 of 13 Posts
How many ft lbs do I need to torque aftermarket aluminum wheels to? 850xp
Most folks do 40-50 ft lbs for the aluminum rims.
Polaris Service manual states 75 ft lbs for the factory alloy wheels.
Would think the aftermarket wheel manufacturer specs would be close.....sure as hell higher than 20 ft lbs.
My SO's 1999 Sportsman 500 is listed at 15 ft/lbs for both front and rear.
I go 75 on the lugs with alum
75 is the spec, but that is too much. You will strip and/or spin the studs. I just get them good and tight using a 3/8 ratchet now. Have never had one come loose.
Your 500 has 5/16" studs the 850's have 9/16" studs and yes the aluminum wheels are supposed to be 70 to 75 steel wheels Are 40 to 45 on the 850 and 550
I do 60 ft.lbs on aluminum wheels.
Discussion Starter · #11 ·
I ended up going with 50 ft lbs. Gonna ride it some more and re torque the wheels.
the 20 pounds was taken from my polaris service manual...i found a few discrepencies in the manual so far...sorry..
.....I just get them good and tight using a 3/8 ratchet now. Have never had one come loose.
This is exactly what I do,.........after breaking three torquing to service manual scecs.
1 - 13 of 13 Posts
