I have a 2002 325 Magnum 4x4. The thing was dead for a few months, ended up having to jump the battery off to get it running. I changed the plug, put new gas in, and a new fuel filter while riding stopped it feathered out and died...Took the carb off jets and bowl were spotless...
So my questoin, is it not getting enough gas? Is it a gas line issue?
Thanks!
Discussion Starter #2
Now with it all back together, it is idling fast. The finger screw on the bottom doesn't seem to be making a difference???
Anyone?
Check the carb boot for leaks where it mounts to the engine. Common failure on them. Also make sure the air box is on all the way and sealed up properly. They won't run right without the air box on.
To check boots, spray carb cleaner on them while machine is running, if it speeds up or slows down, boot is suckin air,
