2003 Magnum 330 4x4 has new battery, new starter. when battery is on peak charge (Just off the charger) starts just fine, If I let it run a while cut it off and try to restart, it will not turn over, battery is not dead but turn the key an nothing... Any help appreciated.
Is it charging while running or not? Battery may be low enough not to start without being dead enough for lights and gauges to work.
Sorry I got side tracked when I went to get the meter, I'll be back at the house in about 2 hrs and will check it and post back.
Try jumping the solenoid with a screwdriver or a pair of pliers when it won't start. Sometimes when they get warm the relay won't make contact when they are worn out.
