New here and just got a 95 Magnum 425 and in the process of fixing it up. I have a problem of the clutch on the belt rubbing the protective housing what is the problem and how do I fix it.
Common issue on the older machines. I've used a heat gun to reshape the clutch cover so the primary doesn't touch it at idle if it hasn't already worn a hole in it. Or get a whole now clutch cover assembly. The new updated one fits better.
