1 - 8 of 8 Posts
hello I have a 1998 polaris magnum 500 4 x4 I have oil in the rad but no antifreeze in the oil res now it will not start anybody have any idea what the problem may be I am thinking head gasket but it smells like differential fluid any help would be great
Before doing a head gasket change I would check for other gasket leaks. Could be leaking from somewhere else. If I came across a problem like that I would spend a few bucks on a service manual or try to find one online. Coolant is pressurized so I would think that you would see it in the oil too if it were a head gasket. Im not sure on the older models just trying to give you some pointers. Hope you get it fixed
thanks for the help will try to find a repair manual online yea want to get it fixed just got it 2 weeks ago rode it 4 time then it stalled while ridding and will not restart checked oil and rad oil fine rad has gray clumpy stuff in it and kind of smells like diff fluid
Sounds like someone poured it full of stop leak, Id bet it had head gasket problems and now it has more problems, is it seized? motor wont turn?
got it started flushed out rad seems to circulate fine no more oil in rad rode for about an hr rechecked rad and no oil
Maybe some stop leak or corrosion floating around in it, or old oil from a previous head gasket or water pump seal leak. Keep an eye on it for a while and see what happens.
1 - 8 of 8 Posts
