I have a 2001 325 Magnum and I'm trying to remove the starter. It appears I will have to remove the drive belt pullys to access the starter....are special tools needed to remove them??
Larry
Larry
A 425 magum starter bolt I think has a 10mm head. But anyway you can buy you a cheap end wrench grind the end down to make it skinny and maybe bend it a little bit. Also they make a open end ratchet wrench. I have only seen tem in a 3pc set. Maybe "ALLEN" brandname sold at Carquest. I will let you know 2moro. Thanks
