I have a 2002 Polaris magnum 325. It has a new key ignition which has been working perfectly (even tried the old one which was sticking, same thing). I went to crank it today and no lights on the dash, no headlights, no crank at all. Starts right up using recall starter. Also starts right up when I jump the starter solenoid. Battery is charged, and ground checks out to several bolts on the frame.
I remember that when the left double kill switch is off, there is no lights on the dash. If I disconnect it, there is no change How can I verify if this is the problem? Maybe it isn’t because it does run. The ignition also does kill the engine when I put it in off position.
Any help is appreciated.
thanks
thanks
