1 - 8 of 8 Posts
hi.I recently purchased a 2002 Polaris magnum 325 2x4. can someone please tell me what kind of fluid to put in rear differential. I have read put agl in it and I've read put angle drive fluid in it. can someone tell me which one to use? I am having a hard time finding a manual for it. also where exactly is transmission drain plug. thanks
For the rear diff. -AGL, synthetic , if you can find some.
Also, most drain plug are on the bottom , you should see a 10 or 12mm bolt on the bottom , for the drain.
Yes.
according to the manual i have , the rear diff. holds 10 oz.
the trans. holds13.5 oz.
States..polaris synthetic gearcase lubricant.
o.k I will put agl in both. thank you for the help. I have a 2003 all models manual and it says agl in both but I also have a 03-05 magnum manual that says angle drive in rear diff. do you know where I can get a manual?
1 - 8 of 8 Posts
