Does anyone know if the 2007 sportsman 700 crankshaft can be taken from other years or models. If you read my other post then yes I'm still in the homework phase.
Also the mechanic said I needed to replace the camshaft and lower housing. There's a very slight scratch noise when they turn. Its not scarred but lightly scratched from I assume low or no oil. Is this ok or should it be replaced.
Thank you
Sent from my SAMSUNG-SGH-I337 using Tapatalk
The microfiche says they use the same crank from 2006-2010. You can look it up here....
Browse
If you slide the parts chart to the side....it will say 'usage'. Click on that and it will show you the years/models that part fits.
Thank you very much. I would assume 800 parts wouldn't fit only 700
