1 - 2 of 2 Posts
2005 Polaris Sportsman 500 H.O. Mossy Oak (Now Purple)
Hola, I have a 2005 Polaris sportsman 500 HO that needs a rebuild, and I figured may as well upgrade it at the same time. Has anyone here done the 600 Stroker? I was curious to how long the process was, and if I do the work, or if he does. I will jet the carb, and put new air filter and exhaust on her too. Thanks.
Your question has now been logged into the queue and the next available forum member will answer you shortly. You will be given more advice than you could hope for.
The real shortage in this country is common sense.
1 - 2 of 2 Posts
