Mikuni carb question?
587 views 3 replies 2 participants last post by  LATEBURD HERE 2 HELP
I have a 1995 425 Magnum with a mikuni carb. It keeps running rich. Took apart jet block to check orings. Bad luck broke one screw. My question is :
Does the hole between the orings on jet block go toward the cylinder or air cleaner???
#3 ·
Latebird your the Master. Thx.for getting back. This rich at idle is killing me. I have been struggling with this issue for a while. I have been lowering the float level about five times and it did help. My next plan is to move the jet needle down. If that don’t fix it ??? My thought is probably checking the cam lopes. Any other suggestions. Thanks again. Glad to see you are still out there.
