2009 xp. have less hp than 2015 ho. I didn't have other models, also frame is little different- "satv" power steering has different mounting plate, battery location -due to frame, and different harnes from bat. can not remember if anything else. so yes. there are changes in 850' over the years... depends on what year you're after...
Sent from my SM-N950U using Tapatalk
Not many!!!! HP jump in 2013. Body face lift in 2018. The SP has close ratio AWD. I mean there are more tweaks here and there like the beefed up EPS bracket but not much of anything drastic.
Have any issues with the 850 been sorted?
I have read of steering issues, clutch issues, and frame issues?
there was also an issue with timing gear slipping, but I’ve read that was sorted around 2014 I think.
thanks.
