Ok, last year I added 2" wheel spacers to the rear of my 05 800 spmn. Moving tires out 2 inches changed the suspension geometry enough to cause the rear of the machine to severely squat under any weight or heavy acceleration. So, I ordered a set of Highlifters springs which are supposed to be 50 lb heavier than stock and it helped somewhat but it seems like my ride height is still awful low (a-arms are straight across with just me sitting on the machine) even with the adjustment cams all the way up. Does anyone make a spring preload spacer like they do for the xp's. I really don't want to use Polaris' spacer as I dont like the split setup. I'm not running Nascar whereI may have to take some wedge out to make er pull harder out of the corners. lol I'd like a permanant fix.
