Hi all. '02 Scrammie 4x4 will not turn awd light on unless I leave switch on and shut down the machine and restart it then all is well, I can then shift from F to R and retain AWD function until I try to switch AWD off and back on again, then no AWD light and no AWD. I checked over a schematic and seems light gets its power from shift switch and override button, but my gear indicators work good, bulbs light up every time. I am leaning toward a bad AWD switch but why would it work by simply turning engine off and restarting? I am going to go hit the switch with my meter and see if I can't peg it as faulty. In the meantime any thoughts on this from more experienced Polaris owners are definitely welcomed.
Thx In advance
The Ridler
Discussion Starter #2
Problem solved. I'm glad I know electronics. I noticed my key switch was a lil stiff and got to thinking 'bout that and the schematic for a sec. Decided to shoot a lil blaster in the hole and bingo a freed up switch and fully functional AWD. Only made sense since I had to turn that switch on and off to get AWD to work. Hope my small amount of frustration saves someone else from the same!!
Scizzo
AKA The Ridler
Welcome to the board!:med:
