1 - 10 of 10 Posts
Banned
OK so I said I would post what I've done. Bought bike new in March 2012.
Yes it's not a Polaris but interesting. I have a book that I write things down in.
*12h/280km
oil
filter
front/ rear diff
trans, air filter
*28h/905km
air filter
valves
*July 27/12
1380km
gearbox
rear diff
air filter
check belt/ blow out clutches
*2470km
oil/ filter
front/ rear diff
gearbox
air filter
*91h/2870km
valves
*July 10/13
112h/ 3721km
oil/filtergearbox
rear diff
dissassemble clutch/ clean & inspect
scuff sheaves belt
air filter
tires are done. new htr 26s
new DP brake pads
*July 28/13
3750km
new gates c belt, old still good
2" rox risers
upper a arm shock mount bolt loose
*Oct 9/13
133h/ 4506km
change sway bar bushings
ballance HTRs
*May21/14
164h/ 5599kms
oil/ filter. switched to Rotella T6
Front/ rear diff
gearbox
blow out clutches, belt good(1.29")
air filter
*June 22/14
5800kms/ 170h
all new garage products bushings
*Aug 13/14
195h/ 6750km
valves
*Sept 12/14
205h/ 7150km
oil/ filter
gearbox
*Sept 19/14
208h/ 7262km
rear diff
*May 5/15
240h/ 8050km
gearbox
oil/ filter
new brake switch
front diff
*July 24/15
253h/ 8531km
regrease one way bearing
Gates "C" belt cracked inside, put stock back on
all 6 clutch rollers flat, rest of clutch in spec
air filter
*Dec 2/15
276h/ 9462km
startor gasket(was leaking)
oil/ filter
*Dec 14/15
284h/ 9893km
starter sticking when hot. BASA check/ clean/ regreased....OK
new Gates kevlar belt
2 flat rollers again!
blow/ check clutches
gearbox
rear diff
*May 14/16
298h/ 10190km
new Dalton rollers in primary
blow clutches
belt good
*Oct 20/16
322h/11100km
oil/ filter
new gasket on clutch cover, pinched/ cut
*Jan 30/17
338h/ 11637km
valves
bolt missing in muffler shield
c rad hose "T" weeping in cold
*April 15/17
339h/ 11644
new twin air filter
muffler heat shield cracked at mount
*May 12/17
344h/ 11800km
front u joint, rear drive shaft
new wear ring
new diff seal
*May 28/17
351H/ 12174km
rear GP bushings worn, sent for warranty
oil/ filter
gearbox
I'm waiting for the new bushings. Hope it's not too hard to read. I'm a fast trail rider. Upgraded to ELKA Stage 1s and now Stage 4s.
Banned
Discussion Starter #2
I also replaced waterpump seal twice, speed sensor, brake switch and key switch when under warranty.
As you can see I change the fluids often. I run it fast but don't kick the crap out of it. No mud bogging. If I have to go through a hole I will, if I can go around I will also.
Still runs as good as the day I got it.
Valves 4x. Just check and adjust to middle of specs. 0.004 & 0.006
I believe it's at 10hrs then every 100hrs after per manual.
How much work is it to get valve covers off on those rotaxes?
The eotax rumble and insane torque has always impressed me.
Banned
July 3/17. 12 280km 357h
Secondary has grooves in sliding half where helix rides
Won't shift 106/107 like a brick wall
Dremeled grooves out
July 17/27. 12914km. 366h
Gates G exploded
Primary has bad levers. Notches on them & worn into side of clutch
Put stock belt back on.
Aug 9/17. 12960km. 368h
New primary and secondary (takeoffs)
Original belt
Front diff oil
Rear diff oil
I had shoulder surgery august 17th. Haven't been out since.
Rotator cuff was torn and bicep tendon had to be screwed in my upper arm (reattached).
I'll be down 3-6 months
Banned
Discussion Starter #10
October 11/17 12970km 369hours
Put new replacement HTRs from Kenda on. Original set always leaked at beads. Kenda replaced for free. Been sitting in garage for 2 years. Filled originals with slime and ran. Still always flat.
Got 6000 miles out of them
1 - 10 of 10 Posts
