1 - 11 of 11 Posts
All fuses are good in the fuse box. Tried a new battery and still nothing. Nothing lights up. Any direction would be greatly appreciated.
to the forum
Check and make sure the RED switch on the left handlebar is in the RUN position. (It's happend before!)
Tire Automotive tire Finger Cameras & optics Camera accessory
If the RED switch is in the RUN position next check for corrosion in the 2 wire plugs on the left handlebar switch.
Automotive tire Wood Plant Motor vehicle Bicycle handlebar
Discussion Starter · #8 ·
If you have a good digital voltmeter start at the key switch does the red wire have battery voltage at the key switch?
Reactions: Gmartino100
2017 Sportsman 850SP
Did you connect the battery correctly? Not to be demeaning, but just like the red kill switch, it’s been known to happen. Some batteries have the pos/neg switched around.
Reactions: FPD218
Play with the key switch. May have gone bad on you.
1 - 11 of 11 Posts
