1 - 16 of 16 Posts
I have a 2012 Polaris Sportsman 800 and in the first year and 300 miles I have had both sides of the rear stabilizer bushings fail, has this happened to anyone else with a newer model? I had a 2009 Sportsman 500 and I did not have this issue, I am wondering if these bushings are defective on the newer models...
Discussion Starter · #2 ·
Has this not been an issue for anyone else?
I am on this forum on a daily basis and this is the first I have heard of this:nixweiss:
I've got about the same on mine and...... I think they are okay. I'll have to look later :D
What is your riding style and terrain? If it's technical I could see these wearing out, but otherwise?
I also read hear frequently and have not seen this as a common complaint. At $8 a pop, that would piss me off a little.
I disconnected the bar on my 550..........not many miles on those worn bushings!
First I have heard of this as well.
faawrenchbndr, how does your machine handle with the bar disconnected?
Discussion Starter · #9 ·
Thanks for the responses! It's not a big deal, just annoying I have to fix crap like this on a year old quad...
happened to mine in about a year but i put over 4k on my 500 in the first year. i took it right off when i put my hd springs in
I replaced mine. Not as bad as yours though. What helped my situation was going to hd springs and cranking up the pre-load.
What kind of cleaner etc. have you used? May be something deteriorated the rubber. They will naturally crack over time but I haven't seen any that bad.
Damn good.........I like it, but I ride slower, technical trails. Rarely do I get over 25. It can be reconnected in a few minutes if need be.
Took mine off my 550 and unless riding double, they will never go back on. You might want to turn your springs up a notch but it rides like a dream. Takes a few miles to get used to it but after a while you just learn to compensate for the leaning in the corners. I have had no problems even at high speed. Mine have been off for about 1000 miles. Kind of like riding a motorcyle. You use your body a bit and after a few runs it just becomes normal to lean into the corners and curves.
Thanks for the info folks...I may try it!
Mine were mangled and squeezed out in 400 miles. Removed all the garbage and never looked back.
1 - 16 of 16 Posts
