1 - 20 of 23 Posts
Tire Auto part Architecture Automotive wheel system Automotive tire
Land vehicle Vehicle Automotive tire All-terrain vehicle Tire
Automotive exterior Vehicle Bumper Automotive wheel system Car
Bumper Personal protective equipment Automotive wheel system Wheel Vehicle
Land vehicle All-terrain vehicle Vehicle Tire Automotive tire
Just some pics of my scrambler I thought id share;
First is space between footwell and 29.5" OL2s
Second is front stance with 4+3 MSA m12 diesels and the OL2s
Third how much the rears stick out
Forth how much the fronts stick out
Last pic shows how close 11 inch wide xtrs come to the sway bar, approximately 0.5" on stock wheels, havent touched in the riding ive done with them on
Discussion Starter · #2 ·
Land vehicle Vehicle All-terrain vehicle Tire Automotive tire
And a couple more of what it looks like now, and the rear stance with before mentioned wheel/tires
Going to lift it and add 31" outlaws this week and put in the QSC clutch kit that finally came in.
Looks like a lot of rubber..... should dig good!
Discussion Starter · #6 ·
R u running stock axles?
2013 850ho
No, Outlaw DHT's, though I never had a problem with the rear stocks for the ~100kms they were in with these tires. Front one sheared perfectly flat tho, I'll take a pic of it, havent yet, was stuck in some deep skeg, first time being stuck too haha, front stock are junk.
2013 850ho
Yea I'm running 27" Zillas and just sheared both my fronts like nothing at the same time
2013 850ho
Discussion Starter · #8 ·
Yeah pretty much useless unless your running stock tires and just trail driving slowly, heres a pic of the bar sheared pretty much perfectly. Have more but internet sucks on a phone, ill add them later.
Discussion Starter · #9 ·
Land vehicle Vehicle Tire All-terrain vehicle Automotive tire
Land vehicle Vehicle All-terrain vehicle Automotive tire Tire
On 31s with 2" lift, wrecked the stability tho
Discussion Starter · #11 ·
I havent had much time with the lift on, only about 25kms, personally I dont like it, cant take as much speed into corners, front end seems to push through corners too, as the rear end has gotten real "slippery", fishtailing just out of nowhere at times, going to try it out with my s/w and see how it feels, could all be a problem of lack of traction from the rear due to the skinnies back there. Ill post once I get the chance to try it.
Discussion Starter · #12 ·
Well finally got to doing some drives with the outlaw 2s and it feels the same as it did before the lift, guessing its a tire prob, not sure if just so tall or too skinny, guessing skinny. Might go to a highlifter 3" during the winter.
Discussion Starter · #13 ·
Changed tires again
I want the OL2 on mine also with some kind of rim? Also getting the clutch kit. I dont want any lift if I dont have to. How much trimming did you do? Also what was the offset of rim?
I don't all my parts are on order right now.
had 30'' sliverbacks with no lift on stock rims for about 1500km... got rid of thems after breaking the front diff cover and other stuff. only thing to do to make them clear was bending the rear part of the footrests using a heat-gun. was not too bad stability wise.
I am too hard on my atv to run big tires like these, but I was always surprised where I could go WOT with these tires! not got back to stock tires size, still breaking and upgrading stuff...
also its almost scary when you realise you can still push it to the rev limiter at top speed of high gear... topping the speedo at 120kmh which in real mean like 140kmh
1 - 20 of 23 Posts
