Does anyone have, or can take a picture of your rear lower a-arm to frame mounting bracket so that I can see if mine is bent?
I bent my 2" receiver hitch upwards using a disc and pushed it back down but I'm not sure if it was just the receiver plate bending or the U shaped arm mount that it bolts to bent as well. I've not got another machine around that I can compare it to.
Thanks.
Thanks. I'll have to check when I get home. Corporate doesn't trust us to view photobucket.... :damnit:
Ok,......will send you a pm
Can you see pics that are posted here?
Nah. Can't see anything linked back to photobucket. Has to be posted up from tapatalk or an attachment on this site before I can see it at work.
See if this works........
Ahhh.. yes it does. Got anything from the side so that I can see what sort of angle it is at in relation to the hitch, ground, what have you? I'm thinking the bracket may be tilted downward now, putting that a-arm in a bind.
Will take a few in the am.........
You are trying to assess if the hitch receiver and structure is bent, correct?
Yes. More specifically, the U shaped structure that the lower a-arm bolts to.
I appreciate it.
