1 - 10 of 10 Posts
Had a mishap over the weekend, bent my front left A-arm. Need a replacement. Where's the best place to get OEM replacement suspension parts? OR does anyone on here have a set of original A-arms that they took off when installing a lift kit?
Will replacing it be a challenge? is it really just unbolt old, bolt on new?
unbolt and bolt back on.
Discussion Starter · #4 ·
Thanks. Was looking on PolarisPartsHouse.com, but PartShark had the part for almost $20 cheaper.
I just bought one off eBay for $40. Cleaned it with carb cleaner, tested grease zerk, sprayed with rattle can and installed. Easy to do. Impact for the castle nut and frame bolts (9/16 if I remember correctly).
about where is a good place to buy parts and especially A-arms (bent mine).
I did look at PartsShark and their prices look really good compared to everyone else...so far.
Was just checking to see if thread was still streaming.
Have you used PartsShark? Or, other recommendations?
Thanks.
that's kind of what it's looking like to me too. Never thought about using ebay as much as y'all talk about on here so I think it's high time to check out Polaris parts on ebay.
1 - 10 of 10 Posts
