I HAVE A 97 POLARIS 500 4X4 EXPLORER. I JUST BOUGHT IT TODAY. THE BIKE WOULD GO INTO GEAR WHILE I LOADED IT UP. IT ROCKED AND WOBELED BAD WHEN I DROVE IT AT HOME AND MADE A CLACKING NOISE. NOW IT WILL NOT EVEN GO INTO GREAR. I MANAGED TO GET IT IN TO DRIVE BUT HAD TO GIVE IT QUITE A BIT OF GAS TO MAKE IT GO. IT SOUNDED LIKE IT WAS SLIPPING IN AND OUT OF GEAR. THE MAN I PURCHASED IT FROM JUST REPLACED THE REAR CV SHAFT ON THE LEFT SIDE BECAUSE HE SAID HE "SHATTERED IT" . THE FLUID IN THE CASE LOOKED NEW AND WAS FULL. OH YEA, WHEN I STARTED IT UP IT ALSO MADE A FUNNY WINING NOISE. ANY SUGESTIONS ON WHAT MY NEXT MOVE SHOULD BE.:hmmm:
take the belt cover off and check belt and clutches, maybe get all 4 wheels off the ground and run it in gear to see whats makin the noise
Sounds like you just bought a lemon!, you didnt ride it before you bought it?, Quad is old, maybe the transmission isnt in gear, i know unless i let mine idle real low it wont go into gear, just grinds
Polaris starters do make a whinning sound thats normal?
As far as the gear problem you need to figure out if its the clutch or trans.
the older models should have an adjustable shift linkage on them, try adjusting the linkage. I need more info on this please
