96 Magnum 425 Chain drive. AWD used to work. Plow snow with it. This past winter, the front right tire stopped working in AWD. The left front tire continues to work. Any ideas? I thought I may have stripped the gears so I pulled the front right apart and it all looks good.
old post but you need to check your fluid. fill with cap at 2 oclock then let drain at 4 oclock and you're good. if thats not it check wiring.
