I have a 2015 ranger xp 900 high output
It has about 53 hours and 259 miles
It was running fine when I parked it with a full tank of gas then I went out this morning and the check engine light is on and it's in limp mode. it is only going 10mph in high and under 5 mph in low only going to 3600 rpm in low and 3800 in high gear. But it goes to 5-6000 rpm in neutral.
The polaris service department here is a month out! Really need this fixed ASAP. Please help me figure out what it is
Thanks for lookin
Thanks for lookin
Have you tried pulling Check Engine codes? The procedure should be listed in your owner's manual.
Going to have to get codes pulled. Only takes the dealer about 5 min with digital wrench. Can't believe they can't slip you in for a few min to plug it in and see what's wrong. May have to wait a few weeks to get them to replace the part, but maybe they can give you the part to replace if it's easy enough.
Try unhooking the positive side of the battery for about five minutes then hook it back up and try it again. I've got lucky with it before. Worth a shot.
Found the problem. Rats had chewed through the wires under the dash that go to the throtle sensor. Thank y'all for all the advice.
