Hi all.
Yesterday noticed that my battery was weak, so removed it to charge.
Once I hook-it up I noticed the fan working, even if no key was there...
Tried and tried until the fan went off and a small burned smell appeared.
Can you believe that I was hooking the battery with inverted poles?!?!?
Once connected the battery again, all works fine, but as I was already expecting after the burn smell, I tried to run the 4 wheeler and the fan does not come up now
Tried to do some troubleshooting and connected the fan directly to battery and works fine. Found out the cable (red with black strip) from the fan goes to CDI
Mostly sure that I burned the CDI, isn't it?
Thanks in advance
P.S: Sportsman 500 H.O. from 2004
Thanks in advance
