Need help with 04 scrambler 500
405 Views 3 Replies 3 Participants Last post by  VanillaGorilla789
I purchased a 04 scrambler recently I have done alot of repairs and maintance on it. Went to make sure the 4wd was working correctly so I jacked it up and started it. I flipped the awd switch and the light comes on. I hit the throttle and only the back and front right tire is spinning the left isn't turning. I have already taken apart the front hubs to replace cv axles which turn and operate great. Something in the hub isn't engaging. Is it possible its just the armature plate is bad? And if the awd light comes on doest that mean both hubs in the front are getting power? This is my first polaris so any help would be appreciated! Thanks in advance!
Font Line Window Pattern Screenshot
to the forum
Ball Gas Font Vehicle registration plate Automotive lighting
See less See more
2
Reactions: 1
No - the light only indicates power to the circuit - you will need to test the continuity of the coil and the physical condition of the individual parts
Reactions: 1
The armiture plate had alot of deep grooves in it. I ordered another one for 8 bucks hope it works if not I'll be testing voltage to the magnet I guess
