1 - 20 of 20 Posts
Hello fellow Polaris owners,
I have sort of a weird request. I'd like to know if any of you have owned a Honda in the past... not early 2000s or older, but a relatively late model, lets say from 2012 until this current model year. I'm in the market for another - just adding, not getting rid of anything. My benchmark right now is a Sportsman 570 SP Hunter Edition. I love it. But I've always wanted a Honda. I need to add another bike because some in my family want to ride. I'd add something small, used and cheap, but right now I have a chance to get another bike I've wanted for a long time, so I am looking at the 2019 Honda Rancher DCT IRS EPS.
I'm looking for your specific input based on your own circumstances.
Has is been reliable? Is it comfortable trail riding? Composed? Enough power? What are the issues you've experienced since owning?
I am going to be purchasing in the next 7 -14 days. Thanks.
My last one before this 570 was a 2010 4wd rancher wth foot shift trans. I bought it used and have no idea of mileage or hours but it was a great machine. It had 26" tires and a lift kit on it when i got it but I quickly found a set of stock foreman takeoffs and removed the lift. I prefer a manual trans over automatic but this polaris is a real runner.
Go for it - they are an excellent bike. But due to DCT they are very picky on types of engine oil due to engine/trans sharing the same oil.
I have looked at them a few times.
Thanks for the feedback. You're right. I think I will stick to the Honda brand oil, full synthetic HP4S. I saw it on Amazon for ten bucks a quart, full case. That would cover it for a while. Some other places are at twelve bucks, and some as high as sixteen. I think it's almost 4 quarts per oil change, too. Not certain, but I thought I saw it at 3.8 quarts per change. Not a cheap hobby, for sure. I spent about half of that on the full synthetic for my 570. But as you stated, it's for the engine and transmission. I will take good care of the tranny, as it's one of the primary reasons I would be getting this bike.
2011 Foreman 500 carb and manual shift with 11,000 miles. Replaced a few wheel bearings especially the left rear. That one seems to go every couple years on the newer Hondas when ridden in really tough terrain like my crew does. Its out in the end of the axle tube and I suspect grass gets wrapped in there and cuts the seal letting water in.
Front shock bearings, ball joints and arm bushings at about 6-7,000 will get a little slack. The shock bearings are overly complicated and expensive.
2012 Foreman 500 EFI electric shift with 14,000 miles. Same deal with rear bearings. That one is mono-shock and had swingarm bearings go bad too. Same deal with the front end as the 2011. It also had the early style fuel filter which clogged up at around 4,000 but no more issues since changed over to newer style filter from Honda. EPS quit at around 8,000 and required a new control unit... OUCH!! About $450 from Honda but I found good used from PSN.
2016 Foreman 500 EFI IRS with only around 500 miles. No problems so far.
All the Honda machines with drum rear brake essentially have NO rear brake after a couple thousand miles and therefore no park brake. The very new ones are disc I think. Time will tell on that.
I thought about a Foreman with electric shift. The SRA is holding me back. I remember riding a friend's foreman with SRA, many years ago. At the time I had a Sportsman 400, probably 15 years ago. I can remember is was a bit harsh. The bumps and ruts were sort of jarring compared to what I had. I am almost there on a foreman, as an electric shift would be more than fine. The horsepower to weight would be fine for my riding style. And I've even test driven them. Very torquey. It had everything I needed with the exception of the IRS. The Rubicon covers that. I'm still kind of considering one of those, too. I just don't know that I need to spend an extra grand for it. Still thinking about it, though.
When you buy, ask for a service manual too, take a flashdrive with you.
Good luck and report back. I may eventually buy one too.
Discussion Starter #8
Wow. This is some excellent information. You're talking about some seriously high mileage on my scale. You've had a few things go wrong, but yet you've continued to purchase this brand. While none of what you stated scared the shit out of me, I think the fact that you've logged a ton of miles, and still continue to buy Honda sort of reinforces what I might be doing in a week or so. I actually feel pretty good about it now. Thanks a bunch for your feedback.
If I were choosing a Honda as a personal ride it would be the Rubicon with IRS and Hondamatic. I love the Hondamatic tranny but they are more maintenance intensive and it take 5 quarts of oil for a change. You also have to drop the skid pan to change the filter.
I forgot about having to change the shift motor and angle sensor on the 2012. They fail pretty regularly on the electrics and Hondamatics with age.
Discussion Starter #10
Pigs would fly before I’d step back to an SRA from irs - you can buy a 500 footshift Rubicon.
Grt the dct eps and be happy.
Discussion Starter #12
The Rubicon is still in the mix. I have until Tuesday to change my mind. I had already told the dealer to email me the VIN on the Rancher because I want to have an insurance policy when I take it home. But he wasn't going to have the VIN until Tuesday. I imagine he will be more than fine changing things up for me.
Can you tell me the most compelling reasons you'd chose the Rubicon over the Rancher?
Sorry to my Polaris brethren for reading about Hondas on a Polaris forum. Please know, that I remain steadfastly in support of the brand. I am just looking for something different this time. But keeping my 570! I love it.
I ran rotella T5 in mine with no ill effects. I was looking at another rancher before I got the sportsman but the machines with irs were a grand more.
Tell you what. I’m Polaris thru and thru. Own 3 of them for my hunting camp.
Hunting friend had a Honda for years and wanted an upgrade.
He felt after long looking and being a mechanic himself, the Yamaha Grizzly was the best bike out there.
I was screaming Polaris to him the whole time.
In the meanwhile I had a friend up north who bought a atv dealership and had a left over new atv he needed off his floor plan. I bought it brand new left over. Called a Hisun 700. Shipped it to Florida.
Buddy finds a Yamaha Grizzly with low miles and upgraded tires in like new condition and buys it, brings it to camp, and I’m like, yeah you’re right, this bike might be better than a Polaris Sportsman.
I take my Hisun out and we notice, both bikes are spot on alike !!! Research tells me Yamaha invested in China to build that Hisun plant using Yamaha old Grizzly plans.
My starter goes bad and I replace it with a Yamaha starter. We’re convinced same bike, different countries of origin.
So what I’m getting at is, if it were possible for me to find an older Yamaha Grizzly in mint condition around a 2012, i’d jump all over it ! That would be the bike for me to buy besides a Polaris and I’m not a fan of the 570 too much.
The Honda run forever. Ride a bit rough, expensive to repair and a little weaker in the mud than a Polaris. They run water pretty good. To me, Honda has the best engines. Suspension is so so and at my age, my back kills me the day after I ride.
Discussion Starter #15
Wow. That's interesting. I've never heard of that brand.
I agree, the Grizzly is really good. I bought my 570 over the Grizzly for the sheer value prospect. I think the 570 is as good in many respects, and better in other respects, like onboard storage, and the number of features for the money. The Yamaha has a great reputation for quality.
Storage in the Polaris stow and lock can’t be beat anywhere shape or form. That front flip box on the Polaris is the sheeeeeet ! I have so many important items I carry in there, plus the rear small box.
Grizzly /Hisun have a circular storage bin. Impossible to use.
Discussion Starter #19
I pulled the trigger on the 2019 Rancher DCT IRS EPS. I will pick it up tomorrow. Thanks again for all of the excellent feedback. It was really useful.
Discussion Starter #20
Picked up the new Rancher yesterday. Put just about 30 miles on it today. It's very nice. The transmission is surprisingly smooth in Auto mode. But it'll go like hell if you give it a little throttle. Bottom and mid-range have really good power. Stout little engine.
I will get some radial tires for it down the road. I want to get good number of miles on it before changing too much. I've attached a picture from the dealership... last time this thing will be that clean. It received a healthy seasoning of dust today. There's a picture taken during the ride... threw on my Polaris bag, as the Rancher has no real storage built in. That bag is 15 years old and still does the job. We bought two of them back in 2004.
Cheers to you. Have a good Sunday.
1 - 20 of 20 Posts
