Hi, I just bought 2 1995 polaris sportsman 400s. Both run and drive but have problems.
Also I was just going to ask what are some things maintenance wise that I should do as the atvs have sat most of the past 5 or 6 years?
fluid change? what kind and where?
belts? chains?
are these decent sportsmans even though there the 2 stroke version?
what is the mix ratio on the engines?
any ifo is greatly appreciated!! thank you
Fluids:
1. Front hubs: Polaris Demand drive fluid
2.Transmission:I use synthetic 80w90
3.Engine Counter Balance:10w30 motor oil
4.Oil injection: I would not trust the injection,bypass and use premix
5.Three Chains:Inspect chain and sprockets and oil them
6.Drive belt: Under left side belt cover, check for cracks, fraying etc.
The 2 stroke models run good but in stock form you must know that the piston is weak and will crack or break, especially after high mileage. The best advice I can give is to get you a service manual in book form or online form. I have a 94 400 sitting in the garage right now.
Discussion Starter #4 (Edited)
Fluids:
Thanks for the help!!! i shredded the drive belt on one today.... and luckily my buddy had a old cyclone sitting around that had a belt that worked.
Is there anything I should look for that isnt obvious for making the belt come apart?
other than weatherd dry rot or just ageing? thanks
could check the motor mounts,make sure they are tight on the motor and frame. there's 3 of them top front rear
