Also I can use the choke to keep it running when it starts to die, doesn't always work though. If that makes any difference
Are you using fuel oil? It is a 2stroke being a 03 if im correct03 scrambler 50. Recent new parts previous owner replaced... carb all fuel lines/petcock/filter, coil, air filter, battery. Its a Clean machine, starts and runs for a min then slowly sputters and dies. You can see there is barely any fuel in the fuel filter. I pulled the lines off the petcock and fuel flows good. I'm trying to verify that the previous owner hooked lines up correctly. From what I can see, this is a gravity fed fuel system do there's no vacuum lines. I even bypassed rhe fuel filter and still does the same thing. The carb isn't pulling for gas if that makes sense? Idk I just need to know if I overlooked something dumb. Thanks
Do you happen to know what the stock jet sizes are? I can order another carb but I'd like to make sure I have the right jets as well.The carb is gravity feed from the fuel tank to the float bowl - puel is 'pulled' through the jets by vacuum (negative pressure) - as engine speed increases the 'load' on the engine is increased, if the spark is not strong enough it will extinguish under increased compression and turbulence. Since the ignition is AC, the generating coils heat up due to increased demand for spark and may ultimately breakdown and fail to produce the spark necessary to ignite the mixture. Now air in the fuel filter is not a problem - fuel flows past the air and on to the carb, but if the float bowl is not vented properly, as the bowl fills, air pressure increases if not vented and at about 6 psi fuel stops flowing and the bowl may not be properly filled. But generally it will be a carb issue. If you buy a carb from Amazon for $20, buy 10 and maybe one of them will work properly. Buy a $45 carb from any other online Chinese parts vendor and it has a higher probability of working without hours of jetting calibration.
This 2t 50cc is a dinli right?The carb is gravity feed from the fuel tank to the float bowl - puel is 'pulled' through the jets by vacuum (negative pressure) - as engine speed increases the 'load' on the engine is increased, if the spark is not strong enough it will extinguish under increased compression and turbulence. Since the ignition is AC, the generating coils heat up due to increased demand for spark and may ultimately breakdown and fail to produce the spark necessary to ignite the mixture. Now air in the fuel filter is not a problem - fuel flows past the air and on to the carb, but if the float bowl is not vented properly, as the bowl fills, air pressure increases if not vented and at about 6 psi fuel stops flowing and the bowl may not be properly filled. But generally it will be a carb issue. If you buy a carb from Amazon for $20, buy 10 and maybe one of them will work properly. Buy a $45 carb from any other online Chinese parts vendor and it has a higher probability of working without hours of jetting calibration.
Pilot jet is a 25 and main jet is a 75Do you happen to know what the stock jet sizes are? I can order another carb but I'd like to make sure I have the right jets as well.
It may be an Eton or a DinliThis 2t 50cc is a dinli right?
Sent from my SM-S908U using Tapatalk
Great. Thank youPilot jet is a 25 and main jet is a 75
I put the stock carburetor back in. Main jet 75 but I can't see any markings on the pilot jet. It's now getting gas but it still idles find then it will idle down low, doesn't always stall. Choke will bring the idle back up.Great. Thank you
