Ok guys here in the next couple of weeka hopefully or month I will be pirchasing and 2012 sportsman 860 XP I enjoy going mudding and want to turn it inro a mudding machine what all do I need to do to head in this direction.
I am wanting to run the MSA Elixir rims 14x7 with the 29.5 Outlaw 2's wrapped around them and can yall point me in the correct direction of 1 to 1.5 in spacer and lug nuts that are compatible with this rim and compatible with the polarises wheel hub also upgrading the clutch assembly.
What do I need to do to the bike to get the 29.5 Outlaws, and z MSA Elixir rims underneath the bike without rub and so on. I had found an 3" lift for the bike by highlifter, but once I do this do I need to replace the axkes do to the rise in height and if so is there anything else i maybe missing that i should take into account that i have not mentioned.
Thank yall for yalls time. C.Clark
Find SOUTHERNMUDJUNKIE!!!!!!!!! He will assist you!!
Thanks for the assistance brother.
Yes sir.. Check for posts from him... You'll see why I say contact him...
