I have a 2004 sportsman 400. Overheats. New themostat. New fan switch rad will not get hot on bottom side. Fan works. Waterpump ? Any help out there for a new member HELP
You may have an air pocket in the block,raise the front end or back into a ditch, start and let idle , fill as needed.
Could check to make sure the rad. fins are clear and clean , to make sure you have good airflow thru them.
Welcome to the board!:med:
