I just purchased a sportsman 850 sage green.
When I place the unit in reverse or H/L then slowly apply throttle it has some lag then all of a sudden , go!
If you hit the throttle quick after placing in Reverse or H/L it grabs hard after a very short hesitation before it grabs the gear.
Is this normal?
Mines the same way, it's been like that since I bought it. 2014 850xp sportsman.
Yes normal operation of the CVT tranny and clutches, you have to get the rpm's up to engage the belt.
Is this normal?
The manual says not to increase throttle slowly, instead use a more forceful push on throttle to get the clutches to grab and hold on tight. This avoids excessive clutch rubbing and related heat.
Now if you're going to travel slowly, less than 10 mph, you should use Low for the same reasons. Luck. :cowboy:
Yea I read the manual where it stated about using low range for pulling and speeds below 7 mph. I missed the part about non light throttle use. Called to ask my service dept guy today, he said what you said.:veryhappy:
Get a QSC clutch kit and you will have all the instant throttle response you will need.
