I picked up a 91 TB 350 4wd on Saturday. I test road it and bought it. It needed a battery and the brakes bled. I fixed the brakes and started it with the pull start and went for a ride. I rode it for about 40 min w/o any problems and parked it in the garage. Went to load it about a hr later in my truck and it took forever to start and barely ran in reverse. I shut it off to move my truck and the quad would not start when I tried to load it. Then the pull start rope snapped... FML.... (this was less than 24hrs of ownership.)
I purchased a new pull rope (not complete recoil) and a new battery. I'll be installing the batter tonight. I did try to start the quad with a battery jump pack and all it would do is click. Starting to think that the starter silenoid is out on it.
Also the guy I got it from said he cleaned the carb out so I'd like to go over his work and check and make sure everything is in stock specs along with a compression check.
