1 - 20 of 26 Posts
Hey guys, picked up a 2010 550 XP with 900 miles on it today.
Knew the rims were the wrong offset but purchased anyway since it was still a great deal.
Now, what I would like to do is sell these rims and tires and go back to something more stock.
Can anyone give me any information on these rims? Tires are Vision Trailfinders (Radials)
Looking forward to learning and chatting about these great Polaris ATV's!
Welcome to the forums! Nice looking machine. Hope you enjoy it.
Dont know about the rims but welcome to the forum and enjoy the 550 mine have been great.
Welcome to the board!
those rims are stock they have the polaris sign right on them, people go to deeper rim offset to add wider tires those are 5+1 5" inside 1" outside. people, like myself upgrade to a 7" wide rim 4+3 offset and tires stick out wider
So which model came with these rims? Do you know?
I know it says polaris on the centre cap, but they also look identical to Vision rims.
if there 14" the xp models do if there 12" value line, but i dont think 12" fit on xp's because they have bigger brake calipers
Front OEM Wheels and Tires
Weight = 30.25 Lbs
Size = 14" X 6"
Offset = 5/1
Rear OEM Wheels and Tires
Weight = 35.7 Lbs
Size = 14" x 8"
Offset = 7/1
do you have 2 8" rims possibly?? thats the only thing i could see making your offset off.
Discussion Starter #10
Weight = 30.25 Lbs
Size = 14" X 6"
Offset = 5/1
Weight = 35.7 Lbs
Size = 14" x 8"
Offset = 7/1
I'll have to take a look.
My front tires are 10's and rears are 12's
I can say with almost 100% certainty that those are not stock wheels. At least not stock to that machine. XP wheels look similar but they are not those. And yes you will need 14" wheels to clear the brakes.
All Stock RZR 800, RZR 570, RZR S, RZR 4, RZR XP, and RZR XP4 (LE or not) factory wheels are:
Front: 12x6 4+2 offset or 4/2
Rear: 12x8 6+2 offset or 6/2
found this turns out there rzr wheels, simple enough, if you want to go to stock you should make sure you can fit a 10" front tire on stock rim offset. also there arent to many rims with stock offset, you'll have more of a selection with 4+3
Discussion Starter #16
Can't be RZR wheels. 12" rims will not fit on the XP. Sure look a lot like the stock XP wheels.
Good point.
I think they are vision wheels. I saw the same ones on a grizzly on the net this morning.
I'll ask at the dealer today.
those are 14" rims 12s dont fit the xp
are the offsets and widths the same as what i stated above to confirm there rzr rims??? just curious
1 - 20 of 26 Posts
