those rims are stock they have the polaris sign right on them, people go to deeper rim offset to add wider tires those are 5+1 5" inside 1" outside. people, like myself upgrade to a 7" wide rim 4+3 offset and tires stick out wider
I can say with almost 100% certainty that those are not stock wheels. At least not stock to that machine. XP wheels look similar but they are not those. And yes you will need 14" wheels to clear the brakes.
All Stock RZR 800, RZR 570, RZR S, RZR 4, RZR XP, and RZR XP4 (LE or not) factory wheels are:
Front: 12x6 4+2 offset or 4/2
Rear: 12x8 6+2 offset or 6/2
found this turns out there rzr wheels, simple enough, if you want to go to stock you should make sure you can fit a 10" front tire on stock rim offset. also there arent to many rims with stock offset, you'll have more of a selection with 4+3
They could be rims that some one bought from Polaris that are not stock offset. Polaris still sales rims that have Polaris center caps but are not stock.
OP, stock rims w/stock offset will be " antikick back " steering wise. Much, much nicer trail ride. This is accomplished because the steering knuckle is on the wheel's centerline with the stock offset.
Ride your bike with the rims you have. As you hit obstacles, you'll notice the handle bars jerking side to side. It may not be as noticeable in the snow.
With stock rims, no kick back, much less fatiguing. You can ride all day and not be tired or " beat up ".
If you ride a lot or on very long rides the lack of kick back is very well worth it. Even short rides are much more pleasant. Why not just go ahead and get stock offset ? I think STI (HD3?) has some with Polaris offset and their new rim (HD4?) is supposed to get it after the new year sometime. Or you could get a Polaris wheel with stock offset.
Just a thought.
Maybe your current rims won't kick back much. Time will tell.
Mostly got it to plow, will be doing some trails in the summer. We'll see how it goes I suppose!
