Hey all, I just got my bike back from a QSC clutch being installed..
They put a new belt in , said the one I had was thin and not as wide as the one they put on new.. I don't know much about belts, but I recall seeing a post here somewhere that you should break the belt in when you install a new one. Is this true and if so, whats the proper method to do so?
Thanks for your time
Some say yes and some say no.... let others say warm the belt up with easy riding before you "put the nut's to it".
Ok, so just easy riding for a bit, Thanks
I posted a reply on your other thread about this.
I say yes to the break in period just to seat the belt well so it makes good contact with both primary and secondary clutches. Just piece of mind.........
lol, thanks bud.. I replied to the other thread..
But how long should the break in period be?
Breaking in means no hard mud play or high speeds correct?
Maybe 25 - 30 miles at most. Just keep from hitting top end for long periods of time. Shut it down after 15-20 minutes to cool it down a bit a couple of times and your good to go. All you want to make sure of is that the belt seats itself good.
what i did to break it in was ride for 15-30 min of normal/easy riding then shut it down and let it cool. The say it hardens the belt? Not sure on that but it seems to work. Then i just rode like i always would. Im not much of a mud guy but i was on the throttle like a raped ape.
