1 - 13 of 13 Posts
I think about getting back into the ATV scene and I notice a lot of complaints about the bushings on Polaris quads. I noticed that the 2014's have different bushing part #, so are they better! or just the same with a different number? I'm thinking about a 2014 scrambler or a Renegade as I am a fast trail rider.
Guess only time will tell? Too new to come to any conclusions
I think about getting back into the ATV scene and I notice a lot of complaints about the bushings on Polaris quads. I noticed that the 2014's have different bushing part #, so are they better?
I highly doubt it :)
The stock bushings are total crap. My hub bushings didn't last 300 miles and I bought the quad new. My buddy has the exact same ATV and his already have play on one side - he has around 200 miles.
The good news is that there is a forum member that makes heavy duty bushings that do not require grease. The entire kit is around $200 and you won't have to worry about them anymore.
I looked at both the renegade and the scrambler. I bought the scrambler because I believed it to have better ride quality. Good luck with your decision
I figured the 14's have been out for a few months now, that some would have some decent time and miles to see how they ware.
If you buy a value model, 400,570,800, you should not have to worry about bushings. It appears just the XP line has that issue.
Grease, grease and grease... thats the only way to make them last. Greasing it almost every ride my last set is still tight after around 2500-3000km
Longer travel suspension makes the bushing spin more and longer a-arms put more stress on the bushing, plus more power, more weight
Same deal for me. I race my quads so they get regreased every 60 miles however most of my race quads with over 600 miles on them still have tight bushings..
The grease I use is "sticky red" by lucas but still.. If you follow the manual then I can see how they would wear out but then it only takes me 5 minutes to grease mine up..
Same goes for all bushings / bearings - all are still tight and move freely..
Still tight after all that....Ok, that's impressive.
and I think we can all agree a tight bush is a good thing!
they only changed the front bushings in 2014 or the short bushings the long rear bushings are still the same
Are you still selling new a arm bushings for the 2013? I need to replace my lowers, front, on my 2013 850, failed with 2238 miles..... Looking for new bushings on the shock mounts as well, upper and lower.
1 - 13 of 13 Posts
