Looking to put in a new (larger) carb in my 2006 Polaris Outlaw 500. Looking at a 42mm or possibly a 44mm (flat slide). Anyone know what I could put in with little or no modifications. Thanks.
Welcome to the board!
according to the parts listing, the 06 pred and 06 outlaw use the same carb, so you could use the big carb on both machines, then it's just a matter of getting the main jet, needle and pilot jet set
hth
Rick Ore :add_twinkle:
Outlaws are truly solid machine. One of the fastest machines out(stock) The IRS is going to be amazing for the trails. I don't know of anything bad to say about them.
Also, here's the cure for this constant problem on the 500 Outlaws. You have to pull the seat to use it but usually that is only a one time thing at the beginning of your ride.
