Ok guys this is my first post so Hello all ,
I am in the middle of a 2000 scrambler 2x4 and have a couple questions.
does anyone know the head bolt torque specs for the 400
second has anyone installed a oil/injector blocker kit,what is involved and do I even need a block plate for that?
any info appreciated
Thanks:D
base 25-29 ft.-lbs.
head 18-20 ft.-lbs.
Haven't done the block off on the 400, but I did on my 1100 Kawi jet ski. Just unbolt the pump and bolt up the block off (yes you need it) and proceed to remove all oil lines and the tank (obviously leave stuff that isn't directly connected/used in the oil injection process). Then just remember to premix your gas!!
