Hey Guys/Gals,
Not sure where to post this so please forgive me if this is in the wrong section. I just recently purchased a Brutus HD with PTO. The attachment I purchased was the snow blower. LOVING the machine but having issues with the blower.
Literally on day two of owning it I blew out the middle two shear bolts on the auger. Called the dealership I purchased it from and asked "what shear bolts should I use"? What shear rating should they be? No one could tell me. So I purchased a 5/16 X 2inch bolt with a rating of 2. First hour sheared off three of the bolts again. The two middles and 1 more middle on the right. This blower has two outer bolts and two inner bolts. So I looked at the two outer bolts and they had the markings on the head of a bolt rated for a 5.
So I went out and purchased a set of 5/16 X 2inch rated at a 5. Used those for about an hour, took one of the bolts out just to see if it was showing signs of wearing. Damn near sheared these off.
I am scared at going to an 8 in fear of damaging the gear box. I have read the owners manual and I am not running the front PTO at more than 2000 RPM's, (running around 1950 RPM) and I am not going too fast through snow either. Fairly confident I am not hitting anything for I have an asphalt driveway.
Anyone with any thoughts on what in the world I am doing wrong, any insight would be greatly appreciated. Since I am shearing off bolts, I am assuming I don't have the correct rated bolt in there. But I cannot find any documentation on what Polaris recommends I use.
Thanks all
P.S. Sorry I wrote a novel.
Thanks all
